Page 18 of 22
FirstFirst ... 8 16 17 18 19 20 ... LastLast
Results 511 to 540 of 656
  1. Originally Posted by Goku73 View Post
    Originally Posted by mctavish44 View Post
    I am getting an
    ERROR: Failed to get KEY, ignore.: One or more errors occurred. (The 'skd' scheme is not supported.)
    on AP*LETV+ (tried with different video resolutions). Decryption does not work, even with the "--custom-hls-key" flag. Also, the key provided by WidevineProxy2 does not seem to match the KID shown in N_M3u8_DL. Can anyone help?
    If you have the right key and you want to decrypt it yourself, you have to use shaka packager and as kid you have to use all zeros, if for example you have this KID:KEY
    000000003fe9e6696331202020202020:8ba8b2ba9e9f0b3f8fcb0ffa70329a27
    you will have to use this to decrypt
    00000000000000000000000000000000:8ba8b2ba9e9f0b3f8fcb0ffa70329a27
    This is only valid for 4ppl3TV
    I want to decrypt an 4ppl3 Music track, and the key is 000000006948dd06001dbd38abe5d4f2:d20bb0c49382c40ce 75ba83d1795c86f. After decrypting, I am unable to play it. Is there an issue with my command line?
    command line:
    packager-win-x64.exe "input=100.mp4,stream=audio,output=111.mp4" --enable_raw_key_decryption --keys "key_id=00000000000000000000000000000000:key=d20bb 0c49382c40ce75ba83d1795c86f"
  2. Originally Posted by Spectrumhsm View Post
    Originally Posted by larley View Post
    ease of use?
    Video not playing is a good thing for me as I don't lose limited tickets to watch.
    As far as I know, on this forum we don't discuss paid services where you lose some kind of tickets each time you reload the page. Anyway, as far as I know, license request happens when the client is already aware that there is an encrypted file, so the "ticket" should be lost already. The best thing to do here is to make sure you can somehow copy the encrypted content from browser cache/memory without initiating additional requests.
    What is much more important in this case, is that with WidevineProxy2 you still have to run official Widevine library, and you can't call that code trustworthy as it is intentionally designed to disrespect its "users". I believe it makes sense to replace the library with trustworthy one regardless of whether you actually intend to download anything, or just stream the intended DRM way. And the library also prints the keys to logs, which is useful.
    You can still use this library together with WidevineProxy2. For some reason playback is still blocked even if the CDM is the same.
    As for ease of use, building it might be complicated, but once the library is put in place, you only need to make sure you are launching the browser from a command prompt/terminal, so that you see the keys when they are relevant.
    Can you please expand on this.
    Can you please give an example of this? What command prompt/terminal are you using and what command are you using to launch the browser?
    Thank you very much.
  4. Originally Posted by Gromyko View Post
    Any Linux terminal emulator, together with a supported browser. See the screenshot made with Ungoogled Chromium. I tested it with LibreWolf too. But not yet tested on Windows.
  5. @ytdlhelp
    Thank you very much for responding. Appreciated.
  6. Originally Posted by petabytenepal View Post
    @ytdlhelp Thank you. Looks like it does not show the keys when using windows. I tried again but still no luck.
    Update: Found a way for Firefox
    Checked it on Windows today, and it seems you are right. When I just launch a browser via command prompt or PowerShell, there is no output. Please explain the way that you found.
  7. Spend whole day trying to figure out for firefox and chromium.
    For Chromium, create a batch file and it will open with console and keys will be shown on console
    @echo on
    "C:\Program Files\Google\Chrome\Application\chrome.exe" --enable-logging --v=1 --no-sandbox
    For firefox it will open console but strangely no output shown, so create a batch file and logs will be added to the file.
    @echo on
    "C:\Program Files\Mozilla Firefox\firefox.exe" --console > D:\firefox_log.txt 2>&1
  8. I also noticed how annoying it is to build this library on Windows. Visual Studio is heavy and annoys me with licensing stuff. So I am uploading the files I built with the first CDM from here on 64-bit Windows 10. Not sure if they are compatible with everything, as I seen "win7" build targets as well, that I didn't use.
  9. Works
    Windows 11
    Firefox 138
    [OpenWV INFO ] OpenWV version 1.0.0 initializing
    [OpenWV INFO ] Registered new session 4260F05A1B12712F939F9E01C25DA086
    [OpenWV INFO ] Service certificate provider: staging.google.com
    [OpenWV INFO ] Loaded key: 509946a848c79cb1c0b2f073997c1aefbe119f23cbd64bf383dd5c7ed2f81aa12a9a7847dcca593c4a04aa2eacbaf31bd34a13f8f329a4e5446203630c41d858 [Signing]
    [OpenWV INFO ] Loaded key: ccbf5fb4c2965be7aa130ffb3ba9fd73:9cc0c92044cb1d69433f5f5839a159df [Content: "UHD2"]
    [OpenWV INFO ] Loaded key: 9bf0e9cf0d7b55aeb4b289a63bab8610:90f52fd8ca48717b21d0c2fed7a12ae1 [Content: "UHD1"]
    [OpenWV INFO ] Loaded key: eb676abbcb345e96bbcf616630f1a3da:100b6c20940f779a4589152b57d2dacb [Content: "HD"]
    [OpenWV INFO ] Loaded key: 0294b9599d755de2bbf0fdca3fa5eab7:3bda2f40344c7def614227b9c0f03e26 [Content: "SD"]
    [OpenWV INFO ] Loaded key: 639da80cf23b55f3b8cab3f64cfa5df6:229f5f29b643e203004b30c4eaf348f4 [Content: "AUDIO"]
  10. Originally Posted by ddll2 View Post
    Works
    Windows 11
    Firefox 138
    Can you help me too?
  11. Originally Posted by ibra View Post
    To get help, you first say what you need help with.
  12. Hi Larley,
    congratulations for your job. Sorry but I'm almost a beginner and I can't make the + button appear at the bottom of the extension. I've already tried many cdm files. The streaming comes from N*w It but I've also tried others taken from this thread. I tried both the latest version, 0.8.2 and 0.6. Same problem...
    [Attachment 87099 - Click to enlarge]
    Sep 2005
    Darkest Peru
    N*w? Stumped me on that one.
  14. Originally Posted by doctorm View Post
    Sk* channels, but I have the same problem on all streams.It almost seems like the CMD file is not being loaded by the extension
  15. If there is some wordfilter preventing from understanding what is being talked about, maybe make a screenshot where the URL is visible.
  16. Originally Posted by ytdlhelp View Post
    ease of use?
    no
  17. discuss openwv somewhere else. this thread is for WidevineProxy2. do you think the kind of person to ask for help because they didn't click 'Enable' in the extension is gonna know how to compile a custom Widevine CDM?
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  18. Originally Posted by larley View Post
    OK, created a new thread for it.
  19. Originally Posted by larley View Post
    These are trolls
  20. I encountered larley's demo page and noticed WidevineProxy2 doesn't work on it, however OpenWV does, even if the same CDM is used. Does WidevineProxy2 intentionally lack support of something, or it is a technical limitation of the way it operates?
  21. Originally Posted by crash8273 View Post
    Hi Larley,
    I solve the problem using Brave browser instead of Chrome. I don't know why 🤔
  22. Originally Posted by ytdlhelp View Post
    neither
  23. Originally Posted by larley View Post
    neither
    OK, I solved it. It doesn't work when "encrypt client ID" setting doesn't match the value it is meant to be. According to OpenWV, client ID encryption is supposed to be enabled for Android devices, except on WidevineProxy2 it isn't, and there is no option to fix it. So it is a bug report.
  24. Originally Posted by ytdlhelp View Post
    That's still not how the server's backend works
  25. Thank you very much my friend, I was able to achieve the result, you are great
  26. Hi Larley,when I run the extension, 2 channel audio output is listed. But in the introduction on the broadcast web page, it is listed as having 5.1 audio feature.Image
    [Attachment 87274 - Click to enlarge]
  27. Maybe 5.1 audio is reserved for higher resolution, can you get 4k resolution?
  28. Yes, I can get 4k resolution. I've seen a lot of videos that say 5.1 audio and the sound is 320 kbps 2 channel audio.
  29. there are some streaming sites that give multichannel audio only on the TV and not in the browser, see n0wtv, maybe mubi is one of them, in that case you will never be able to take multichannel audio in this way, but my guess is just a guess
  30. Got it, thank you my friend.
